Old 04-01-2021, 06:47 PM   #1
Default Replacing old tv
I’m wanting to upgrade old tv with newer bigger model. Any suggestions. Have PleasureWay Excel, 2009.
jston1 is offline   Reply With Quote
Old 04-01-2021, 07:37 PM   #2
I used a Samsung T22C350ND in my 2006 PW Lexor TD
it replaced an older 17 or so inch
I fabbed a little bracket to mount it on the swinging door
it is DC native, so low(er) energy use
has a media player and usb so I can play 200 movies from a thumbdrive, rather than boxes of dvds
I also have a similar samsung in our guest room a 32", also native DC ( look for the models which use a transformer)
they both came from costco, $130 and $160
the 32" wouldn;t easily fit in the van the way we use it.
I have seen large monitirs in vans though
Old 04-02-2021, 11:46 AM   #3
Default Replace tv in Pleasure Way
Thanks, Mike.
Old 04-02-2021, 11:47 AM   #4
Mike do you have any pics of it. What size tv is it? Thanks
Old 04-02-2021, 11:50 AM   #5
Default Replacing tv in Pleasure Way
What size tv? Any pics of project?
Old 04-02-2021, 02:12 PM   #6
@Michael's Avatar
Jensen also makes 12V Tv's specifically for boats and RV's.
https://www.jensen-electronics.com/marine-televisions/
2019 Coachmen Crossfit
Old 04-02-2021, 03:17 PM   #7
the tv is a 21 or 22" it came for costco, I do not thing that T22C350ND model is still available
...also has a headphone out which worked perfectly with the van audio system
pics:
https://photos.google.com/share/AF1Q...VxLS11aFNDb2pn
Old 04-02-2021, 03:32 PM   #8
DaveBad's Avatar
I have a 2008 GWV. 3 yrs ago I replaced my tv with this:
https://www.amazon.com/Axess-15-6-In.../dp/B07NF9BZ1J
At the Time I paid $130. I wanted a small DC unit with more modern connections and a built in dvd player. I ended up adding on a Roku to make the tv smarter.
If I had to do it again I would look for a 12vdc smart TV with USB inputs.
DaveBad is offline   Reply With Quote
Old 04-02-2021, 06:42 PM   #9
Skyworth is a popular brand which is also popular with long haul truckers. They are ruggedized for use in a vehicle. They are available over the interney and at large truck stops. I have had good success with Skyworth with a built in DVD player.
Old 04-09-2021, 08:52 AM   #10
I added an Amazon Firestick to an older 19" 1080P non-smart TV in my RV, and love it. I couldn't find a 19" 1080P TV anymore.
The Firestick is so good, I bought another one for a Samsung smart TV, because the UI is better than Samsung's. And this way, it's all on one account and both have the same remote control button layout. Plus, the Alexa PTT voice command feature built in the remote is sometimes useful.
One last comment that bears attention. If you're on a capped data plan, the Firestick can adjust the download speed under Settings/Preferences/Data Monitoring/Set Video Quality. It doesn't tell you the exact download speeds but gives you a choice of Good/Better/Best. Using "Good' dropped my daily usage from 10GB/day to 2 GB/day. The nicer weather also helped .
Nic7320 is offline   Reply With Quote
