Old 07-22-2013, 07:47 PM   #1
Default Replacing Door Retainers
I need to replace damaged door retainers on the side utility doors. The old ones are fastened on with rivets. How do I remove them without damaging the door itself? Thanks for your help.
dorains is offline   Reply With Quote
Old 07-22-2013, 08:28 PM   #2
Mike's Avatar
Default Re: Replacing Door Retainers
Need a lot more info.
Make, model, year of class B van.
By utility doors, do you mean the external storage compartment covers/doors?
Upload/attachment (tab located below this window, when posting a message) a photo of the problem area, if possible.
Old 07-23-2013, 12:26 AM   #3
slipbobber's Avatar
This is a tutorial that I have recommended in the past. Great info.
http://www.overclock.net/t/337343/how-t ... -replacing
When you retire from fishing, then what?
slipbobber is offline   Reply With Quote
Old 07-23-2013, 03:01 AM   #4
Mike's Avatar
Doh!! I was getting ahead of myself and thinking in terms of replacing the keyed latches, not just removing the existing rivets.
Drill works, and is the only way I've seen used to remove rivets.
Nice tutorial, btw, slipbobber.
