Old 02-07-2019, 12:43 AM   #1
Default Replacement ultraleather seat bottom covering for Pleasure Way
Does anyone know where I may find replacement seat coverings for the bottom part of the ultraleather Captain's Chair on a 2014 Pleasure Way Ascent?
Derivative_Guru is offline   Reply With Quote
Old 02-07-2019, 01:53 AM   #2
Have you called the factory?
Old 02-07-2019, 02:35 AM   #3
Yes, they just sent me their Dealer list and said contact one of them and let them contact the parts department. I have contacted a Dealer and they are asking PW. I posted here in case anyone knew of other options if that doesn't pan out.
Old 02-07-2019, 02:55 AM   #4
They probably will want you to buy a whole seat set so they don't have to break one up. Color matching over time can be an issue.
Have you tried to find a local auto upholstery shop. They will use the existing for a pattern and make one on site. Look for a place that does street rods or restoration stuff. Most areas of the country will have one or two, or even more of those shops fairly close by.
Old 02-07-2019, 01:40 PM   #5
Have you tried to find a local auto upholstery shop. ....
+1. A good local shop will tell you on sight what the specific ultraleather is - they won't even need to look it up. And they can match it so closely that you'd probably never be able to tell that it's a replacement.
Old 02-14-2019, 05:46 PM   #6
Yes, our powersofa in our PW was recovered. We contacted the factory directly. They sent the material to Wagontrain RV (now Van City) in Las Vegas who did the recovering. The cream sofa match is good but slightly off of the driver's and passenger's chairs which were not recovered.
Ray B is offline   Reply With Quote
