I have purchased two of the Thetford 10' Fixed Length hoses Model 70425. The first one leaked from under what I call the collar (the hard part at the end of the hose). I returned it and ordered another one, both from Amazon. That hose leaked in the same spot. I contacted Thetford and their Customer Service said they would need the name and model of the macerator in order to know why, even though I explained that I had connected it to a section of the original hose, using their adaptor, and not to the macerator itself. Then they said I might have gotten defective hoses. I will return and order a new one, but I am doubtful that is the problem.
I ended up purchasing a length of 1 1/4 inch bilge hose from Ace and was able to use the macerator again. The hose is white and see through to a point, so I can see "stuff" moving through it. The only issue I have is that with out an air release, the "stuff" moves slowly as the air has no where to go, if that makes any sense. So maybe the Thetford hose is supposed to have an air vent, but I don't know how to hook it up to prevent "stuff" from leaking out on the ground when dumping. Photo attached.
