Old 09-02-2019, 01:33 AM   #1
blackbourn3704's Avatar
Question Replacement light fixture for '95 Roadtrek 190.
I am looking for a low profile replacement for the head scalping light fixture in the rear of the van. The attached picture is what I have now. It is a 12 volt circular fluorescent tube fixture. All the small LED fixtures I have looked at have a limited area coverage. Has anyone found a good replacement for this type?
To B or not to B? B, no question about it!
blackbourn3704 is offline   Reply With Quote
Old 09-02-2019, 05:08 PM   #2
I bought this:
I reused the switch from the old light (mine looked like yours, 99 Roadtrek popular). Drilled a 3/8" hole in the side to mount it.The light is made out of aluminum.
Ed
RedPanEd is offline   Reply With Quote
Old 09-04-2019, 05:22 AM   #3
Thumbs up Thanks
Thanks. I will check it out.
Bob
Old 09-04-2019, 08:57 AM   #4
This is the exact replacement but it has gotten expensive.
Thin-lite - Round Light Led Clear - Led109cxlp - Explosive Powersports
http://www.solarseller.com/thin_lite...led_lights.htm
Same depth as original. Excellent two level light.
Old 09-08-2019, 05:26 PM   #5
Default LED option
I put in this very low profile LED light in June. So far I have been very pleased with it. It mounted very easily and actually has two mode: a bright warm white and a low blue light.
sg13 is offline   Reply With Quote
Old 09-08-2019, 09:09 PM   #6
Hello
I hit my head on that a hundred times.
What I did was really simple.
I removed the old bulb and starter.
I installed five small square glue in place leds.
I then bought I really nice looking frisbee.
Used the same old switch.
Drill a hole in center of frisbee.
Now I have a light that uses next to no power !
Is nice and bright!
It is super low profile!
And cost almost nothing!
And in a pinch..... me and the Yorker can play frisbee!
If you would like to go this way and want a picture or two.... let me know
Eddie
Eraygunz is offline   Reply With Quote
