Re: Refrigerator on the road
Kinda think that the DIY has hit a wall.
Running propane down the road can be chancy- and all that should be off if you pull in for fuel.
a wireless thermometer ( $10 walmart) can give you an indication of how the food is doing while you drive, and if any adjustments need to be made to the controls on the fridge.
( on shore power mine can be set on "2" to maintain 37º...but on 12 volt I gotta switch to 4 or 5- ambient temps in the 70's)
for the electrical system there "should be"( in a professional installation) a car battery and a coach battery...the coach battery should be able to recharge when you are driving off of the alternator, or when parked from shore power or the generator.
as above there should be a magic box under the hood to supply power to the coach battery.
I'd suggest that you have someone who is savvy to RV's have a look and tell you what you have and how to operate the systems...which switch needs to set at which position under which circumstance for the desired result.*
Your model is not uncommon and I betcha you can find some help easy- or even find a similar model on your local classifieds and go look at it....see if the under hood stuff looks the same.
2.) a fan kit to move air across the fins of the fridge can really increase effectiveness when parked...if it starts off cold...it'll do a better job of staying cold.
* I am totally new to my used PW, and most of my time has been with manual and flashlight tracing down the systems and running components in the driveway.
