Old 05-17-2020, 11:12 PM   #1
Default Rear shocks
While inspecting my 2001 roadtrek 190 popular on a dodge I was looking at the rear shocks. I would like to replace them however there doesn’t seem to be enough room to remove them from the upper mount. The mounting stud is pointed toward the shower pan and I don’t believe there is enough room to slide the shock off after you remove the nut. Have any of y’all run into this problem and what was your solution ?
Thanks for any help,
John
Jbell is offline   Reply With Quote
