Old 01-18-2023, 03:25 AM   #21
Anyone have any insight on this?
Interestingly, the Centurion label states that the battery charger will automatically stop charging when it senses the correct battery voltage. I believe that this unit is a 2 stage charger, which as I understand it is sufficient if the unit is only charging the battery - i.e. plugged into shore power while in storage. However, when this is not the case, the other items in the DC circuit will cause the charger to keep charging the battery if there are other DC items in use. In other words - if storing the RV my Centurion 3000 should be OK, but if using the RV I am at risk of boiling the electrolyte.
2001 Yamaha XT225
2002 Roadtrek 190 Versatile
www.roadtrek190.com
Kurt Franz is offline   Reply With Quote
