Old 10-24-2014, 12:23 AM   #1
Ron
Default Re: Need Name of Following Item
Would like to have the correct name of the following item #1of 2
Ron & Rose Cabral
New Bedford, MA
2010-Chevy/RT-190P
FMCA:303873 ~K1RRC~ RRRCRT@aol.com
Ron is offline   Reply With Quote
Old 10-24-2014, 12:26 AM   #2
Ron
Need the correct name of the following item #2, 2 of 2
Ron
Ron & Rose Cabral
New Bedford, MA
2010-Chevy/RT-190P
Old 10-24-2014, 12:48 AM   #3
#1 is Ethernet cable plugged into your Tripp-Lite inverter. That cable will lead to the remote switch for the inverter.
#2 is a battery disconnect
Old 10-24-2014, 12:50 AM   #4
AKA "CAT-5 Patch Cable"
Old 10-24-2014, 05:16 AM   #5
Correct on both counts, but the often-called inverter is more correctly an inverter-charger: It can convert (invert) 12vdc from the batteries into 120 vac when not plugged into shore power or on the generator, OR it can charge the batteries when plugged into shore power or on the generator. The Ethernet cable is connected at the other end to the inverter on-off switch near your fuse box and other electrical switches and readouts. Turning this switch off only turns off the inverter function; the charger function is still active (with shore power or generator) UNLESS you change the position of the little slide switche actually on the inverter-charger to the right of the blue cable to the center ("DC off") position.
The battery disconnect shown is a latching relay, meaning that it can stay in either on or off position with no further power. It gets a short shot of power to change its position by the momentary switch also on the electrical panel (probably the monitor panel, but I'm not positive about your model). Pushing the top of the switch is probably the "on" position, pushing the bottom is probably the "off" position. The switch returns to its neutral center off position when you release it, but the relay stays in the last activated position until you change that.
Regards, Dick
