Old 05-01-2018, 09:59 PM   #61
Boxster1971's Avatar
Originally Posted by InterBlog View Post
Here are the two questions I posted on the YouTube site (my husband asked ARV previously about the inrush current and, at that time, they did not know):
Why are the heat exchanging surfaces teal blue in color? Should they not be bare aluminum? We have a big problem in the deep south with air conditioning components rotting out prematurely if they are not all copper and aluminum construction.
Also, when and how can we get data on the inrush current at startup? Those of us who run our a/c for periods of time off our lithium battery and inverter need to know that information.
Looked like anodized aluminum to me. That would help make the aluminum more durable.
- - Mike
Old 05-02-2018, 03:42 AM   #62
Arlo's Avatar
Advanced Fest starts Friday. I hope to get a first hand look at everything under development. Anyone else going? Last message they sent they had said 50 RVs were attending.
I’ll be at ARV Fest too. Missed meeting you last year. It was a fun and informative weekend.
Sent from my iPad using Tapatalk
Old 05-02-2018, 02:38 PM   #63
Originally Posted by Boxster1971 View Post
Looked like anodized aluminum to me. That would help make the aluminum more durable. ...
Yes it could be, but I wasn't going to lead the witness. I want to have ARV offer the confirmation in their own words, if that's true.
I've learned that "looked like" and "should be" are right up there with "assume" where air conditioners are concerned. Most owners never crack open their units, and so some manufacturers do tend to hide sins inside of them. We replaced our stick-and-brick a/c system last year. I was amazed to find that, while the main visible lines were indeed copper and the heat exchanger was indeed aluminum, the portions of the lines concealed inside the aluminum fins... THOSE portions were galvanized steel. So of course they rotted out in short order, costing us many thousands of dollars for a replacement unit.
Last year, we opened up our old lumbering deafening Dometic roof unit to install the EasyStart. I was pleased to see correct configuration of metals. The red arrow in this photo is pointing toward the EasyStart, but if you look near my husband's left elbow, you'll see the beginnings of the copper that runs all the way through the aluminum. No sins were visible, no corrosion was visible. Now, if only the danged thing weren't so loud...
Old 05-04-2018, 03:11 PM   #64
I'm glad I didn't lead that witness, because the reply I got on YouTube was much more interesting than if I had done so:
"Thank you for your question, Interstate Blog. Both heat exchangers are made from high grade copper and aluminium. The fins have that light teal blue tint because of a very thin polymer coating applied to both surfaces of the aluminium. The polymer coat is hydrophilic – which means that it is literally ‘water loving’. This hydrophilic coating allows condensed water to run off the fins without wanting to bead and block up the narrow air gaps between the fins. This gives a better performing heat exchanger that delivers excellent air flow regardless of the conditions. Another benefit of the coating is a reduction in corrosion as water tends to run off the fins. The corrosion resistance with this polymer coating is better than having bare aluminium fins."
Old 08-16-2018, 02:04 AM   #65
Did anyone end up getting the Quiet Air Conditioner? How is it working?
hrewer is offline   Reply With Quote
Old 08-16-2018, 02:45 AM   #66
wincrasher's Avatar
Marlon Knox on the Facebook Travato group had one installed and thoroughly documented the project. He's very happy with it and posted videos where you can hear how quiet it is. Cost him ~ $2700.
2019 Winnebago Travato GL
Old 08-16-2018, 11:51 PM   #67
It's nice that it comes with a remote control and an actual set temperature readout on the unit itself.
I was REALLY impressed with his after install video where he was talking and listening to the TV in normal tones while the air was running in the backround
Bob & Sharon
Old 08-17-2018, 01:27 AM   #68
I was visiting ARV few days ago and had an opportunity to look at installed unit. It is not completely silent but it is high quality really quiet device. Unfortunately cost of installation on my Transit was much higher than I'm willing to pay. In general I was really impressed with Bs they produce, ARV craftsmanship and engineering are excellent.
Sprinter54 is offline   Reply With Quote
Old 08-17-2018, 01:38 AM   #69
Did ARV give you a price of $2700 also for a Transit?
pattonsr is offline   Reply With Quote
Old 08-17-2018, 01:57 AM   #70
Is there a link to the video?
I am scheduled for an install in Nov when we return from Alaska...
Old 08-17-2018, 02:08 AM   #71
yes. problem increasing the cost of installation was my van. I have cut out for MaxFan too close to the rear doors and air conditioner can not go there because it will overhang. Placing it in front required moving at best but more likely replacement of 360W solar panel changing the way it mounted, disassembling ceiling and so on.
Old 08-17-2018, 07:52 PM   #72
Let it overhang; you will have more space for solar panels.
