Old 10-02-2011, 05:16 PM   #1
Default PW Rust Problems
Just bought a used 2008 PW Excel TS. Two rust related problems are at the top of my list.
One - the rear passenger side locked compartment has a faulty gasket and the screws/pop rivets are rusted. Has anyone replaced this gasket - if so where did you order it from? Since the compartment is a nylon shell - would it help to have a drain hole in it or ??? I live in S. Florida where heat and humidity go hand in hand.
Two - the rear bumper over the hitch appears to be badly rusted from the inside. Has anyone run into this and how did you handle it. Not sure I can do much without taking the bumper off. Any ideas?
Thanks,,
https://i517.photobucket.com/albums/u...20TS/th_RV.jpg
Gail and Bill Burkett
Jupiter, Florida
burkettwh is offline   Reply With Quote
Old 10-03-2011, 01:12 AM   #2
Default Re: PW Rust Problems
I'd probably go with POR15 products based on what I read.
http://www.por15.com/SUPER-STARTER-K...ductinfo/SSKB/
Currently I''m using Rust Check http://www.rustcheck.com/ to try to prevent rust.
