Old 08-31-2020, 03:51 PM   #1
Default Propane valve replacement
Hi All
Just join you group. I have a 1997 Road Trek D190 Versatile. Have a question about replacing the valve on the propane . Is this the correct place to ask this question . If not where do I go
davehicks686@gmail.com is offline   Reply With Quote
Old 09-03-2020, 03:47 PM   #2
mloganusda's Avatar
I see no one has answered your question about propane valve replacement. Are you asking about the main valve that turns on the propane? You can go to a propane dealer and ask them if they can replace the valve for you. If so, they have to empty the tank to replace the valve.
MLogan
Smyrna, TN
Old 09-04-2020, 10:57 PM   #3
I believe that mlogan is correct. I had a propane valve on the tank replaced because it was leaking around the stem. They have to void the tank to do that which is something that I'd never do. It was a fast 30 minute fix at a LP place (not a RV place).
