Old 06-07-2024, 03:47 PM   #1
@Michael's Avatar
Default Propane Solenoid failed ?
I have a Coachmen Crossfit with what seems like a failed propane solenoid. There is power to the solenoid, but I don't hear the thunk that it normally makes, and of course have no propane at the appliances.
The valve looks like a model V20533.1p like this :
https://store.nashfuel.com/products/v20533-1p
Does anyone know if I can replace the solenoid without replacing the whole valve?
2019 Coachmen Crossfit
Old 06-07-2024, 09:37 PM   #2
I recently replaced the solenoid on my 1999 RT 170. It is a different style than yours (see the pic below), but it was all just one unit. I am not sure on your style of solenoid, but I would be surprised if any part of it could be removed and replaced independently because I would think that the parts function interconnectedly. But mine was 1/4 of the price of yours, so I can see why you would want to try if it is possible!
Old 06-10-2024, 11:39 AM   #3
Smack it with a hammer on a screw driver. Worked for me. The oder agent they put in propane can collect and gum it up.
As for replacing the solenoid I would guess no.
Old 06-13-2024, 05:39 PM   #4
A cheaper alternative to the solenoid - but with a long lead time.
https://americancng.com/products/rot...lacement-a1572
I bought two to keep one on hand.
You can test the 12 volt power to the solenoid first though to make sure you do not have a bad switch. When on the solenoid is warm/hot to the touch.
The solenoid it self can be tested with a meter for resistance, you can google it.
Finally you could use this strong magnet to test or temporarily hold open the valve:
XLMB is offline   Reply With Quote
Old 06-13-2024, 11:04 PM   #5
@Michael's Avatar
Thanks for the links.
I checked the solenoid - it's not passing any current, so likely dead. I can't tell if the valve is stuck or not. Tapping on it didn't make any difference.
I'll try the magnet trick, and order a solenoid. I found one in stock at Nash Propane, but its 4x the price.
https://store.nashfuel.com/products/...42789434753181
--Mike
Old 06-13-2024, 11:25 PM   #6
Contrary to my previous post if the solenoid can be removed (snap ring) it can be replaced. The solenoid isn’t sold alone so it doesn’t make much difference.
And now I see it is sold alone. My older RV uses a manual valve. Inconvenient sometimes but it does have it’s advantages. No current draw for off grid camping being the main one.
Old 06-16-2024, 07:05 PM   #7
@Michael's Avatar
I ordered that magnet, which was able to pull the valve open. So the valve is not stuck. The solenoid is toast. The good news is that I can use the magnet until I can find a replacement solenoid.
Thanks for the tip.
Old 06-17-2024, 12:18 AM   #8
Thanks for the tip.
Glad to hear that you have a workaround until the new solenoid comes in.
propane, solenoid
