Old 09-25-2024, 02:23 PM   #1
Default Propane Pressure Regulator
I have a 2005 Roadtrek 210. I changed the water heater, turned the propane back on and got a lot of hissing. I am assuming that the regulator is bad. I have not removed old yet. Question is: what regulator should I use? I believe mine vents down. Is it the MEGR-298?
Thanks, Bob
2005 Roadtrek 05C210v
2020 Can Am Spyder RT Limited
Bangorbob is offline   Reply With Quote
Old 09-26-2024, 03:15 PM   #2
If it were me I would diagnose the actual leak before loading the parts canon.
A big leak should be easy to find.
Old 09-29-2024, 10:45 PM   #3
Why do you think it's the regulator? If the last thing you touched was the connection to the water heater, then I would check that 100%
