Old 06-24-2018, 05:00 PM   #1
Default Propane adapter
I have a conversion van with a permanent propane tank mounted on it.
The fill valve is large, about 2”. Some places only have a small fill hose to fill propane tanks.
Do they sell an adapter that I can mount to the tank fill connector that reduces to the smaller propane tank size?
Thank you
Toolman0114 is offline   Reply With Quote
Old 06-24-2018, 09:39 PM   #2
It's hard to know which adapters, but once you take some measurements, I'm sure there are adapters for everything.
For example: https://www.campingworld.com/maintai...hoses-adapters
The only problem you might run into is trying to fill a tank that has a type of fill that is no longer allowed by law. I remember about 15-20 years ago, some of grilling propane tanks had an old style, and I had to trade in those tanks, and buy new ones. If you have one of those, it may be that even adapters won't help.
davedutah is offline   Reply With Quote
Old 06-27-2018, 12:33 PM   #3
Habril's Avatar
I have a pencil flame torch and a 14 OZ tank and i like to attach the pencil torch head to a small Nica tank and also be able to refill the 14OZ tank
Habril is offline   Reply With Quote
Old 06-27-2018, 12:40 PM   #4
I ordered this adapter. The large end will fit on the propane tank fill valve, the small end will allow a smaller BBQ tank fill hose to fill the main tank.
