Old 02-10-2015, 04:13 PM   #1
Default Promaster Travato floor insulation
I'm installing a side screen on my Promaster build the same one used on the Travato, after dry fitting, I'm guessing the floor of the Travato in not insulated. Does anyone know what is the floor construction of the Travato is?
Old 02-10-2015, 05:00 PM   #2
Default Re: Promaster Travato floor insulation
I had heard it was 20mm thick which is about 7/8 inch thick, so it doesn't sound like a lot of insulation depending on the thickness of plywood used.
Old 02-10-2015, 06:24 PM   #3
If its 7/8", then there isn't any insulation. No room after the flooring.
Old 02-10-2015, 08:50 PM   #4
That is something good to know... at the minimum, to toss a rug or two down.
Old 02-10-2015, 10:01 PM   #5
Found out they do put insulation down, a couple of mils.
Old 02-11-2015, 12:17 AM   #6
Where's wincrasher when you need him??
Bob & Sharon
Old 02-11-2015, 03:29 AM   #7
wincrasher's Avatar
Sorry, I don't spend every waking hour on here - I have a business to run after all.
I'll have to measure mine and report back. I'd be surprised is it's any more than a layer of dynamat and then the plywood.
I had once posted a video of the insulation going on the walls, but I forget where it is. It may show what's going on with the floor.
None of these vans is going to have much on the floor. Some may spray the underside of the van. Winnebago doesn't.
2019 Winnebago Travato GL
