Old 04-02-2022, 02:51 AM   #1
Default Promaster 2021 vs 2022
Anyone know when Dodge started delivering the new 2022 promaster chassis with 9 speed transmission to the OEM rv manufacturers? What month of the 2021 year?
OnNTwo is offline   Reply With Quote
Old 04-02-2022, 01:00 PM   #2
I read somewhere. A 2021 Promaster used for deliveries. Person could never get his transmission into 7,8 or 9 gear? Some others also experienced this. The supposition is, weight of vehicle(loads) needs to keep transmission at lower gears to maintain speeds?
Just something to think about. Maybe a 9 speed transmission is overkill for the the engine and most applications?
2016 PW Lexor TS
Old 04-02-2022, 01:24 PM   #3
More specifically, it is the gear ratio's that prevent running in higher gears. Or, ok, not enough low rpm torque/hp.
The C8 Corvette has 8 speeds, but it has the low rpm torque/hp to use them at it's weight. The Promaster does not at 3500 Class B weights.
Old 04-03-2022, 03:52 PM   #4
This doesn't come out until the 2022 models... the 2021 has the same transmission since our Ducato clone arrived. Which might explain why his 2021 doesn't get to gears that don't exist yet. lol
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
