Old 09-30-2021, 08:43 PM   #1
Default Problem with pairing BMV
Sorry for the previous text.
I have an issue with pairing my upgraded iPhone with the VictronConnect 712 bmv. I contacted Victron who said the unit is still connected to the old phone. I reset the old to factory settings before shipping it back.
Does anyone know how to resolve this issue. I tried disconnecting the shunt and reinstalling without success.
chet is offline   Reply With Quote
Old 09-30-2021, 08:57 PM   #2
I don’t have Victron, but in general, wiping the old phone just means the Victron thinks the phone went away and will come back. You have to tell the Victron to forget the old phone so it can find the new one.
Old 09-30-2021, 10:16 PM   #3
How long did you disconnect the Victron 712? I believe it has some memory so may take a bit of time before it can reset? I have the same unit. A total disconnect will do it but may have be overnight?
Old 09-30-2021, 10:55 PM   #4
Rlum
Thanks for that suggestion; I will try that now. Will post tomorrow. Thanks again
Chet
Old 10-01-2021, 01:01 AM   #5
make sure your iphone didn't copy over the old settings for bluetooth devices
if so, delete the device from the bluetooth settings
delete then reinstall the app, unless there is stored data you must save
try re-pairing
for something like that i would use an old iphone in airplane mode ( no sim), that's what I use for the obdfusion app I use to monitor the motor and tranny
there are potential security issues where an app like that may be reporting your location, what speed you drive, when you are awake or asleep, the other apps on your phone and how you use hem- thousands of data points may be transmitted
which may allow 3rd or 4th parties more info that you'd want
https://www.washingtonpost.com/techn...hone-tracking/
Old 10-01-2021, 03:15 AM   #6
Mkguitar
The phone does not recognize the victron. Bluetooth is searching for a device and the victron app tells me to enter the password which it won’t accept. Therefore no pairing. The manual is worthless when it comes to this problem and tech support hasn’t really helped either.
Old 10-01-2021, 06:18 AM   #7
The most common blue tooth pairing PIN is four zeroes in a row, 0000.
Two others you may encounter on some devices are 1111 and 1234.
if that doesn't work, look for the serial number, it could be the last 4 digits of that
mike
Old 10-01-2021, 03:43 PM   #8
I tried:
Deleting the app and reinstalling, disconnecting the BMV overnight, multiple passwords (factory default is 000000), shutting down the phone with no luck. I appreciate all the suggestions though. Thank you
Old 10-01-2021, 05:18 PM   #9
Sorry I don;t have a victron, so suggestions general in nature
on one of my devices ( odbfusion through a bluetooth OBDII reader)
the bluetooth connection is not made through iphone "settings" but through the app itself under communication in the menu
This requires the iphone bluetooth on, but nothing paired or active
the in the app selection communication
I wonder if your victron has similar procedure
odd victron can't/ won't help
I have tweeted them with a link to this thread, maybe they will respond with a solution
mike
Old 10-02-2021, 01:19 PM   #10
According to the manual you can reset the BMV by pressing and holding the Select and Setup buttons simultaneously for 3 seconds.
Old 10-02-2021, 02:41 PM   #11
Unfortunately that didn’t work either but thanks for the suggestion.
Old 10-02-2021, 02:44 PM   #12
Thanks Mike
Everything that was tried has failed. Victron tells me the the unit is still paired with the old phone. Hopefully they can come up with a solution
Old 10-02-2021, 04:29 PM   #13
Instead of just telling you it's still paired with the old phone, they should be telling you how to make it forget (unpair) the old phone.
Old 10-02-2021, 10:47 PM   #14
Amen to that!!
Old 10-03-2021, 06:05 PM   #15
Found a thread on another forum. See #10 and hard factory reset.
https://www.foreforums.com/index.php?topic=41303.0
Also default bluetooth setup code is 000000 (six zeros)
Manual https://www.victronenergy.com/upload...R-DE-ES-SE.pdf
Good luck
Ken
