Old 08-25-2008, 02:44 AM   #1
Default Priming a genset
Has anyone experimented with a method of priming a genset? They always seem to bleed the gas back to the tank and it is wasteful to crank the engine until the gas getsto the carb.
I have read that newer units have a prime function by pressing the "off" switch. Seems that a diode installed to run the electric pump but now close the starter relay would be the answer. A pressure switch with a "ready" light would comp[lete the system.
I know - - start it more often!
Thanks for reading.
JA
K1smm is offline   Reply With Quote
Old 08-26-2008, 10:21 PM   #2
Not much help, I know.. But I have a can of starting fluid (ether) for balky engines.
Chip
Boondock traveler, Frugal, but never "cheap".
Cornbread Red is offline   Reply With Quote
Old 08-27-2008, 01:19 AM   #3
I carry a can of starting fluid in my boat because many more than one time it has failed to start at a bass tournament. Apparently the same problem as your genset, the gas drains out of the carbs.
kenking is offline   Reply With Quote
Old 08-27-2008, 01:59 PM   #4
I'm not sure that they make a one way valve for gas lines but that would stop the draining if it were available .
RS 38-40 is offline   Reply With Quote
Old 08-29-2008, 02:55 PM   #5
On the Roadtrek group, I read a suggestion to start the van motor before starting the generator.
I don't know if that'll help or not.
My Onan has the switch you describe - press it until it lights up - then start the generator.
Old 09-03-2008, 05:04 AM   #6
Mike's Avatar
We didn't try the gen until a few days after we brought our RT home. It turned over but wouldn't catch. I did start the van's engine and then tried it again, and it fired up (Onan Microlite '02 RT 190P).
Mike.
