Old 07-01-2021, 01:12 AM   #1
Default Potty Question
As evidenced by every pit toilet, poop often defies the law of gravity and goes sideways instead of down. Flush toilets address this with swirling water and brushes. I guess cassettes, etc., get cleaned with brushes? How do composting toilets address it?
I pondered this recently when I realized this is a non-issue with bag 'n bucket because the chute is the bag that gets tossed every day.
Old 07-01-2021, 03:57 AM   #2
Moving the vehicle from time to time helps. If not, I hear you end up with a pyramid.
Stevemo is offline   Reply With Quote
Old 07-01-2021, 01:02 PM   #3
I'm not referring to the pyramid. I’m referring to the stuff that goes sideways.
Old 07-01-2021, 02:00 PM   #4
Poke it with someone else's finger?
Want a B is offline   Reply With Quote
Old 07-01-2021, 03:21 PM   #5
I’m not understanding the sideways comment. Are you talking about diarrhea? In gravity toilets you are suppose to put water in the bowl prior. The poop pretty much slides and settles over the gravity dump hole. There is a spray hose in every gravity toilet I’ve had that you can spray down any remnants, or I guess you could use a brush. Good question about composting toilets since they are suppose to be water separating. Nobody ever mentions it or the preparation of coir in what is evidently a non-compost mix remaining in the bowl.
Old 07-03-2021, 12:52 AM   #6
https://compostingtoiletsusa.com/pro...-head-10-pack/
Old 07-08-2021, 06:38 PM   #7
Default Jug of Water
We keep a gallon jug of water in the wet bath. Before the flush , pour about half from about 2 feet help breakup the horizontal issue and everything goes down Keeping bowl atleast half full helps as well.
Ebyronjr is offline   Reply With Quote
Old 07-08-2021, 09:06 PM   #8
Half gallon per flush?? That adds up quick. I can shower in a half gallon.
