Old 08-13-2022, 05:07 AM   #1
Default Pleasureway hitch mounted cargo box
We have a 2000 Pleasureway Excel on a Dodge chassis. Will I be able to carry a cargo box on rear hitch?
badbeeoh is offline   Reply With Quote
Old 08-13-2022, 06:25 AM   #2
you should be able to find the specs for that ( for instance my PW Lexor on a chev is 5000/500)
I have a harbor freight aluminum carrier- on my most recent trip I had a large home depot storage bin attached to it with a couple dozen self tapping screws. it holds our inflatable kayak and other stuff. leveling blocks.
total weight on the receiver is about 150
total cost about $110
Old 08-13-2022, 11:54 AM   #3
I would say yes. Just make sure to purchase and install a class 4 hitch. Better to over engineer and anticipate hitch sag. Curt and Draw tite make decent ones.
2016 PW Lexor TS
Old 08-16-2022, 06:18 PM   #4
If you have the factory PW suspension, etc., adding that weight to the rear of your unit may negatively affect handling. There is already too much weight behind the rear axle. I believe the hitch itself weighs 60lb. Add cargo to that figure.
HWDean is offline   Reply With Quote
Old 08-16-2022, 06:29 PM   #5
You are correct. The hitch weighs about 65 lbs. Not much weight can should be added to the van. I added Sumo Springs and the Super Springs(extra leaf) and Bilstein shocks. After all of these suspension upgrades, the van drives much better. Although a bit stiffer, handling is more responsive.
2016 PW Lexor TS
