Old 09-27-2020, 06:07 PM   #1
Default Pleasure-Way gate valve replacements
Replacing my gate valves for the black and gray water lines in my '04 PW Excel TD (Ford). Black is a 3" valve with 48" cable. Is the gray a 2" or 1-1/2" valve with 24" cable? And any advice on the project (including parts brands and vendors) would be helpful. Thanks!
FrugalRV is offline   Reply With Quote
Old 09-27-2020, 10:50 PM   #2
There a probably a hundred threads here on the subject & thousands of posts.
They are seem to be the same.
I no longer use my Black Tank but a 5.5 Gallon Porta Potti - I still have all the plumbing & the last I had it repaired, Valterra.
gate valve, pleasureway excel, sewer valve
