Old 05-11-2021, 05:22 PM   #1
Default Pleasure Way 2010 PSI setting for water pressure regulator
I just purchased a 2010 Pleasure Way and the manual suggested using a water pressure regulator. What PSI should the regulator be set to?
Thanks,
Sandi
Newsan5 is offline   Reply With Quote
Old 05-11-2021, 06:34 PM   #2
Hi and Welcome to the Forums
My 2006 PW Lexor came with a camco- they are under $10 amazon or camping world, probably walmart ( which usually has a good stock of RV stuff)
make sure your water supply hose is "safe" for drinking water- usually colored white
https://www.amazon.com/Camco-Pressur...xpY2s9dHJ1ZQ==
before our first trip ( and with very limited experience) I practice camped in the driveway to learn all the systems --- where I had access to internet, phone and a full tool set.
It also helped me determine which tools etc I needed to carry.
Cheers, Mike
Old 05-12-2021, 01:41 AM   #3
Thanks,
Sandi
Hi Sandi:
According to most people. 40-50 psi. I set mine to 40psi to be safe. I would be reluctant to leave on when leaving for a day outing. A fellow RV person said. He previously owned a boat. The technician stated, he saw lots of boats sunk at the dock. Caused by a leak in the pex pipe when connected and unattended.
Old 05-12-2021, 03:11 AM   #4
I fill my fresh water tank under pressure and to prevent possible tank rupture set my pressure regulator down to 30PSI.
Old 05-16-2021, 05:33 PM   #5
My advice, use none. City water hookups are a waste and can cause damage. Fill up your fresh water tank and call it a day. It takes about 5 minutes every few days, depending on your usage! Keeps water fresh, easy to unhook and run into town or whatever, no chance of busted pipes or a flooded RV. I could go on, but it makes absolutely no sense to me why anyone would use the city water hook up. Just my two cents...
pleasureway excel, water pressure psi
