Old 02-20-2015, 11:31 PM   #1
gordonhks's Avatar
Default Pathetic Sprinter Horn
The horn on my 2012 3500 Sprinter is a joke. It is weak and wimpy. I almost feel like apologizing when I honk it. Has anyone upgraded theirs?
Gordon H
2013 Great West Van Legend SE
gordonhks is offline   Reply With Quote
Old 02-21-2015, 04:33 PM   #2
Default Re: Pathetic Sprinter Horn
upgrading a horn is pretty easy- you'll find horns at your local autoparts store.
some may require a relay- esp air horns.
some will just plug into place and replace your stock horn
a quick and easy job which if you are an electrical novice will give confidence.
complete kits from fiamm or wolo with a relay etc are available.
I have an air horn on one of my motorcycles, swapped the prius horn for a pair of horns from a 1980 volvo...have used 1966 Cadillac Fleetwood horns on another motorcycle....and a 3rd bike uses a 6 volt horn on a 12 volt system.
each of these is substantially louder than many vehicles on the road
in particular the stock prius horn was near inaudible- I;m sure if works fine in Tokyo- but it was ineffective if the person on the phone was wandering into my lane.
mike
Old 02-23-2015, 04:58 AM   #3
Johnny R's Avatar
[quote="mkguitar"]I have an air horn on one of my motorcycles...
Not meaning to hijack this thread, just ask a question. Is there a delay between the time you press the horn button and the air horns sound? If not, what brand/model did you install?
Johnny R
Johnny R is offline   Reply With Quote
Old 02-23-2015, 04:19 PM   #4
No delay, the compressor is directly attached to the horn diaphragm.
this one is HD's own which has been good- there is a tube for the air intake and a little oil in the tube once in a while to lube the compressor.
part numbers: 69415-05A, 69000035
I tried a horn from howards some years ago it quickly failed.
for a car there are less expensive units with plastic horns- under $30 with relay and wiring
Old 02-23-2015, 04:56 PM   #5
A pair of horns is likely doable without additional modifications. There is also Hornblasters as well, if you need real awakening power, but that might take a 12 volt run.
