Old 09-12-2022, 05:49 PM   #1
Default Onan oil change
Just to confirm - drain the oil - add 1 quart of correct oil - done
2002 Chevy Roadtrek 190V
https://www.roadtrek190.com
Old 09-12-2022, 08:11 PM   #2
Which model of Onan do you have? Some of them only take 19-20 oz of oil?
2016 PW Lexor TS
Old 09-13-2022, 03:22 AM   #3
Microlite. The stock unit that came in an 02 model Chevy.
Old 09-13-2022, 12:55 PM   #4
I would get the model # and look up how much oil required. I believe it will probably be less than 1 qt.
I have had two Onans. First would only take 18-20 oz of oil. Second would take a full qt.
You can also just add 18-20 oz. Use the dip stick to check before adding anymore. Adding too much oil is a problem. I have done this and had to drain and re do the oil change.
2016 PW Lexor TS
Old 09-13-2022, 02:13 PM   #5
eric1514's Avatar
The fun begins when you realize you can't pour the oil back in.
Get a pump. They make some that screw onto the top of a quart bottle of oil.
"Il Travato Rosso"
2015 Travato 59g
Old 09-15-2022, 05:07 PM   #6
I second the pump suggestion. I had a problem with the output tubing kinking as it made a sharp turn to the oil fill on the Onan. To fix this, I added a rough "spring" made with stiff wire, which causes the thin tubing to follow a gentler curve.
Old 09-18-2022, 09:26 PM   #7
Yes one quart. 08 Chevy Lexor TS
Old 09-18-2022, 09:30 PM   #8
As others have mentioned, the pump is a must. Once you get one, make sure it screws on to the oil bottle. Mine only fits the smaller diameter bottles.
Old 09-19-2022, 03:30 AM   #9
Perfect. Thanks.
