Old 11-25-2020, 12:31 AM   #1
Default onan 2800i
this seems to be what was discussed in the past. new quieter onan
https://www.cummins.com/generators/onan-qg-2800i
Old 11-25-2020, 02:30 AM   #2
yes, winnebago has it in the new EKKO...
someone is trying to figure out if you can set it up to auto start when the batteries get low to recharge the lithium batteries. not clear it supports the standard onan auto start set up
Old 11-25-2020, 03:49 AM   #3
Hi Greg, how are things. How's your BIG mama
Old 11-25-2020, 04:24 AM   #4
Fine, been hiding out in the UP of Michigan for the last 5 months avoiding people...
Old 11-25-2020, 08:14 PM   #5
https://powersuite.cummins.com/sites...lic/S-6505.pdf
on the second page of this link it says accessories=energy command 30. auto generator start
i think thats the ec-3o ?
Old 11-25-2020, 08:37 PM   #6
We have that Onan control panel in the big brown truck but you cannot use the auto start with lithium batteries, highest trigger voltage for starting the generator is 12.5v which is too low for lithium’s.
Our generator auto starts from a command in the Mastervolt system that controls all the electrical system.
Old 11-26-2020, 05:00 PM   #7
I found this-it sure sounds quieter
Old 11-26-2020, 05:32 PM   #8
It is a significant improvement to the previous model, on the occasions we ran ours overnight to get air conditioning in our Roadtrek the noise was loud and the bed vibration was like those motel coin operated bed vibrators you used to see.
Old 11-26-2020, 05:33 PM   #9
I did find a Xantrex generator auto start module that can be used with lithium batteries.
Old 12-03-2020, 07:39 PM   #10
JPMcG's Avatar
My Onan 2500 Microlight LP died. I just bought the close replacement. Looks like the QG 2800 but LP and lower KV output. QG 2500 LP it is almost a bolt in fit (I hope) The old one --might get repaired ???? and put on the market.
Any interest out there --I'm in Rhode Island ?
JPMcG is offline   Reply With Quote
