Old 06-21-2023, 03:57 PM   #1
Default onan 2800 generator question
I need to replace the material that is on the inside of my onan 2800 service access door. It looks like a foam material covered with a black silk like material. Maybe a heat shield or sound deadener? This material is torn and wore out and needs replacing. Anyone know where I can get this material? Thank you
ph007 is offline   Reply With Quote
Old 06-21-2023, 04:43 PM   #2
DaveBad's Avatar
You may want to contact Cummins to verify the correct part you need.
https://shop.cummins.com/CSSNAStore/...r%20insulation
DaveBad is offline   Reply With Quote
