Old 04-08-2016, 04:57 PM   #1
Default Onan 2.8 Generator
Does anybody know what the compression of the engine should be? Thanks for your input
95Pop210 is offline   Reply With Quote
Old 04-08-2016, 05:04 PM   #2
It is listed at 8.5 to 1 ratio in the literature I have seen, so it would be in the 120 psi range ideally, I would expect. I would expect to be over 90-100 would be OK. Valve clearance adjustment can alter the reading, along with worn rings or valves.
