Old 05-27-2008, 08:58 PM   #1
dave_in_delaware's Avatar
Send a message via Yahoo to dave_in_delaware
Default Olympian Wave catalytic heaters...
Does anyone here use one of those Wave-3 or Wave-6 catalytic heaters (http://www.uscatalytic.com/uscatalytic/Heaters.cfm) for their RV, instead of an installed furnace? I've looked into these heaters and they sound perfect:
- uses low-pressure LP gas
- heat thru chemical reaction (flameless combustion)
- low intensity infrared heat
- no heat is lost through a vent or flue
- 99.98% efficient
- can be wall-mounted or portable
- safety
- low cost
So, does anyone use one of these in their RV?? What do you think?
Dave
Current Project: Design Phase of a DIY "Sportsmobile" in Ford E-350 EB, to include: L-shaped sofa/bed, Storage cabinets, Sink, water heater, porta-potti, 2 AGM, solar, hydronic heat, attic fan, propane, portable frig...
dave_in_delaware is offline   Reply With Quote
Old 05-28-2008, 04:55 AM   #2
clickable link: http://www.uscatalytic.com/uscatalytic/Heaters.cfm
I don't know much about catalytic heaters at all but I found a ton of links for more info
http://sierranevadaairstreams.org/owner ... aters.html
http://www.damouth.com/RVStuff/PortHeat.shtml
http://www.fiberglassrv.com/board/index ... opic=26522
http://escapees.infopop.cc/eve/forums/a ... 022912/p/2
All of the links indicate that you need have a windows slightly open for safety (carbon monoxide) and that the catalytic process releases moisture (humidity) into your RV if the the Catalytic heater is not vented to the outside.
The biggest advantage (other that low or no power consumption) is that they are silent or very quiet.
The standard furnace used in most RV's are noisy!
Old 05-28-2008, 08:47 AM   #3
I have a little Coleman "tent" heater that has a built-in stand and battery powered fan. Biggest complaint is the amount of moisture catalytic heating produces.
For electric hookups, I take along a radiator-style 1500 watt electric heater. Never had it above lowest settings yet and it doesn't make any noise.
VernM
GMC Conversion Van and WellsCargo traiiler
https://www.classbforum.com/images/1994%20GMC.jpg
VernM is offline   Reply With Quote
Old 05-30-2008, 07:29 AM   #4
g1g
I don't know any details but is it possible they could burn up to much oxygen and not leave enough for you to breath. Even with a safety swith it may fail.
