Old 06-14-2022, 04:56 PM   #1
Default OBD2 Bluetooth
Anyone have a recommendation on a OBD2 Bluetooth scanner that has proven to work on the early model Chevy Roadtrek with an android phone? I took a gamble and bought a cheesy blue ELM knockoff for $4.00 hoping I would get lucky. Would rather use my phone than invest in a scangauge at this time.
If you have found one that works please let me know the exact model.
Thanks
Old 06-14-2022, 05:04 PM   #2
with my iPhone I use this- it is rock solid
Veepeak is good about customer service and they may just give you a discount code if you email and ask
on my 2005 chev the OBD port stays energized- I bought this cable with a power switch inline
it also keep me from kicking the dongle with my big feet when setting the parking brake
Old 06-14-2022, 07:19 PM   #3
I just replaced my ooolllldd bluetooth thingy with this a couple of weeks ago.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
This on a '97 Chevy P30 chassis and I use Android. Works a treat once paired.
On TDY in windy Walden, CO.
Old 06-14-2022, 08:15 PM   #4
Thanks fellas! Lotsa crapola out there in addition to knowing which protocol is needed for our GM vans.
Old 06-16-2022, 06:08 PM   #5
have it working - appears to be no oil pressure and/or trans oil temp - unless there is some PID programming necessary - still digging into this...
Old 06-16-2022, 06:11 PM   #6
i use OBDFusion
there is a PID for tranny temp
not sure about oil pressure, as the van has one
that app has dozens of pids available
Old 06-19-2022, 09:56 PM   #7
I use an OBDLink MX Bluetooth with the ODBLink app (for my Honda) and the FORScan app (for my E150 van) running on an Android phone. The setup is reliable and gives me all the information I need. Using the Windows version of FORScan I can modify parameters in the Ford modules. (I have changed the TPMS thresholds and disabled the annoying "Welcome light" feature.
Jim
Jim86301 is offline   Reply With Quote
Old 06-20-2022, 02:04 AM   #8
Try FIXD car diagnostics works android and iPhone from Amazon
Renwick is offline   Reply With Quote
Old 06-20-2022, 08:50 PM   #9
Originally Posted by mkguitar View Post
i use OBDFusion
Did you have to do anything special to get the tranny temp to work? I have added it but no activity? Maybe I am missing something...
Old 06-20-2022, 09:36 PM   #10
Menu
- add display
select display type, I use digital
next
select colour
next
in display configuration, click on PID
next window takes you to PID
select USER DEFINED PIDS:
scroll to tranny temp
click done
if after doing this you don't get tranny temp, I wonder if your ecm is sensing that or making that available.
- my chev chassis is 2005
mike
