Old 10-14-2015, 11:49 PM   #1
Default now this is strange
so im monkeying with the rv today...took the pannels off the roof to rewire and have it plugged in for the first time in 6 months or so.
im inside eatting lunch when we hear a sort of soft explosive noise from the back yard.
my first thought is batterys just went so i run out back and nothing seems amiss....no smoke/ fire etc. look toward shed ( gas cans propane bottles etc in there ).
check inside of rv and batteries charging happily...nothing wrong...
hmmm....so i do a full walk around and almost miss this. WTH?
ever have this happen ?
ander is offline   Reply With Quote
Old 10-15-2015, 12:27 AM   #2
What is the tire brand, model and date of manufacture?
Old 10-15-2015, 01:07 AM   #3
Bruceper's Avatar
That's a serious failure for a tire that wasn't loaded.
I'd go see a dealer about that.
Old 10-15-2015, 01:18 AM   #4
looks like a uniroyal laredo made in 0711 if im reading it right.
had new tires put on when i bought it...shop said spare looked "ok"... i know better now.
Old 10-15-2015, 02:04 AM   #5
Boxster1971's Avatar
Looks like and old tire. If that tire is more than 6-7 years old just be thankful you weren't driving on it.
Old 10-15-2015, 04:48 AM   #6
Wow! How is that possible?
sammie14 is offline   Reply With Quote
Old 10-15-2015, 12:19 PM   #7
Post a photo of the DOT code if you can.
I posted some DOT code info here: http://www.classbforum.com/forums/f5...code-1837.html
For tires manufactured before the year 2000 the last three numbers of the DOT code indicate the week and year of manufacture. So if the last three numbers are 496 that means the tire was made in the 49th week of 1996.
For tires manufactured after the year 2000 the last four numbers of the DOT code indicate the week and year of manufacture. So if the last four numbers are 5208 that means the tire was made in the 52nd week of 2008.
I've never seen anything like that
I pay attention to DOT codes now on used vehicles after determining the tires on my van dated back to 1997 when I bought it a few years ago.
It will be interesting to confirm the age of the tire. 2011 is not an old tire.
Old 10-15-2015, 01:58 PM   #8
eric1514's Avatar
Almost looks like someone took a shot you.
"Il Travato Rosso"
2015 Travato 59g
Old 10-15-2015, 02:21 PM   #9
OK, now I've found several similar failures (links below) .............. and it looks like all the spare tires failed at the top ( 12o'clock approx).
So what's causing it? UV concentration at the top? Condensation causing rot?
5 links to other similar failures:
http://arveeclub.com/forum/index.php...0136#msg310136
Boat trailer tires..The good bad and the ugly! - The Hull Truth - Boating and Fishing Forum
Spare tire blowout! | Fugawetribe
spare tire blow out - The Hull Truth - Boating and Fishing Forum
RV.Net Open Roads Forum: Spare tire blew on back end of trailer
Old 10-15-2015, 02:25 PM   #10
Any chance you backed into something at some point in the past?
Old 10-15-2015, 03:07 PM   #11
An Error Has Occurred!
I find it strange that every one of those failed spare tires exploded in nearly the same spot on top of a spare mounted vertically in an exposed location. Is this some physics principle? Seems like more than coincidence.
Old 10-15-2015, 05:42 PM   #12
It seems to me the top of a spare tire would be under a bit more stress than the rest, with the weight of the two sides trying to pull it in opposite directions putting it under tension - even more so when you're bouncing it up & down while driving. And if the tire is never rotated or removed from the mount, it's the same spot holding up to that tension for years.
2003 Roadtrek 190 Popular
Gryphon is offline   Reply With Quote
Old 10-16-2015, 01:03 PM   #13
Grypon, that's plausible - but on the other hand, the weakest part of the tire is the sidewall. So, why wouldn't all those tires mounted horizontally underneath the frame and bouncing down the road explode as well? Could it be they are protected from direct exposure to sunlight? The OP's tire was also "protected" from sunlight by the cover. Fascinating
A 2014 Ocean One MB Sprinter by Advanced RV named "Imagine"
mikes47 is offline   Reply With Quote
