Old 03-26-2017, 01:28 AM   #1
Default Nib broken off on drain pipe
The bottom nib (or nipple) of my waste drain pipe got broken off when I got high centered in a rough parking lot. Fortunately no greater damage happened, but now the end cap will not stay on the pipe (the original one was lost in the process). And when I couple the waste hose to the pipe, a leaky connection is made--definitely not desirable! So how should I proceed from here!
gksmith is offline   Reply With Quote
Old 03-26-2017, 02:42 AM   #2
If you have enough pipe, just cut out the broken part and replace it using a PVC or rubber sleeve. The parts are readily available and cheap.
If not, either:
(a) make a new nib by carving it from a little piece of PVC and glueing it on with pipe glue
(b) build up a new nib with epoxy.
or
(c) drill a little hole where the nib goes and make a nib-equivalent with a machine screw and a couple of nuts. Coat it with epoxy.
Old 03-30-2017, 01:26 AM   #3
Thanks for the suggestions. I do not live close to an RV dealer, so I was concerned about the best approach. The end of the drain pipe extends about 1-1/2" beyond the brace holding it up, so perhaps a coupler and a new piece with nibs might be the best way, if these pieces are made. Would Camper World have these? We are going to Nashville very soon, so perhaps I can try there. However, I do not see it in their catalog.
I had considered your "C" suggestion, drilling a hole and inserting a machine bolt the same size of the nib. I like your suggestion of covering it with epoxy. So, if I cannot find a new end piece, I will most likely use that suggestion.
Again, thank you!
Old 03-30-2017, 01:46 AM   #4
eric1514's Avatar
Termination Adaptor
"Il Travato Rosso"
2015 Travato 59g
Old 04-01-2017, 11:12 PM   #5
Thanks. It is now ordered. Amazon has everything, doesn't it! I had not thought to check there.
Old 04-06-2017, 09:36 PM   #6
I have received the waste line termination adapter and went to glue it on. However, there is some play between it and the existing waste line. It is close, but I can definitely move it a small fraction of an inch (32nd??) when placed on the line. I have never worked with this type of material, but I suspect that this is too much play for a satisfactory glued fitting. Is there some material I could wrap or apply to take up this play when gluing? Or will applying the ABS cement to both pieces take up this slack?
Old 04-06-2017, 10:54 PM   #7
That is kind of strange. The specs on plastic plumbing pipe are pretty tight, so I am guessing that one or the other pieces is not Schedule 40. I don't think using pipe cement would work well--they work by melting the plastic, so they are not space-filling. If this were a pressurized pipe, I would start over and do it right. Since it isn't, I would probably glue them using epoxy, which does fill space. That would be kind of a kludge, but I suspect it would be fine in practice.
Old 04-10-2017, 04:17 AM   #8
Avanti - thanks for the input. I have found some JB Weld epoxy that is designed for plastics. I have not used it yet, but I think it should be the perfect material for the problem at hand. Thanks again!
Old 04-10-2017, 10:56 PM   #9
The latest on my situation--after sawing off the remaining nib (only two to start with), the fit of the terminator hub onto the drain was tighter than I thought it would be--not snug, but very little play. So I decided to use the ABS cement after all as I felt that there may not be enough space for the epoxy. Time will tell how it turns out, but I am hopeful. It was a simple solution if it does work out.
