Old 06-19-2013, 03:47 PM   #1
Default newbie here - refrig help?
Just bought a 1987 Ford e250 Dearborn RV body van. Old, runs great and most everything works. Dometic refrig seems to have an issue with running on AC - won't come on. I think its a manual switch problem. Anybody have an advice - about the refrig or anything else?
Thanks, JanJ
jansj is offline   Reply With Quote
Old 06-19-2013, 04:05 PM   #2
Default Re: newbie here - refrig help?
Does it run on gas? If so, that is a good thing, since it is still usable even though it might be tough to find a burner element for it.
Old 06-20-2013, 07:31 PM   #3
Thanks
Old 06-20-2013, 10:19 PM   #4
Have you checked things like the AC panel circuit breaker for the fridge? Also, make sure the fridge is plugged in and you could test the outlet where the fridge plugs in to make sure it works.
