Old 04-12-2021, 05:10 AM   #1
Default new water pump, low flow to toilet
2015 Roadtrek SS Agile... I replaced the water pump, same model as original. Straightforward job gave me no problems. New pump works well to kitchen sink but very low flow to toilet.
If I take it out, how do I determine if there's some sort of blockage to that part of the rig? There's only one "out" from the pump before it splits into two directions.
Thanks for any ideas!
mattbaxter is offline   Reply With Quote
Old 04-22-2021, 05:19 PM   #2
Sounds like a bit of debris found its way into the toilet supply leg. See if there's a way to disassemble that leg at both ends and blow the line out. Disassemble the toilet valve and look for a defect or debris leading in.
buzzards27 is offline   Reply With Quote
Old 04-22-2021, 05:22 PM   #3
I had this issue with our 2014 190P. I removed the toilet, which was very straightforward, and found debris (appeared to be bits from the hot water anode) blocking the inlet. I cleared the inlet, ran some water through the hoses, reinstalled, and all was well.
jamesv999 is offline   Reply With Quote
