Old 04-02-2024, 08:39 PM   #21
I see a lot of talk about blowouts, tread separation etc. I also notice that people do not talk about tire maintenance. Run a tire 20% under recommended pressure for any distance and it can destroy a tire. I have TPMS and a compressor and will not drive 1 foot on a low tire!
https://www.rvtiresafety.net/
Old 04-02-2024, 08:50 PM   #22
Originally Posted by Beachlife View Post
Hello everyone, I have had a recent vibration issue with my newer Class B Travato 2020 vibrating and bumping in the rear. I recently changed oil and had the tires rotated. The tires have 30,000 original miles. I think it may need new tires, alignment, and shocks. The rattle was way too much on a short trip. I plan to have everything checked out and what ever items anyone recommends checked.
Any brand of tire for a smoother ride is requested??? All options
A good shock to put on this newer vehicle. I have the Sumo suspension.
Thank you all and hope everyone had a great camping summer even with the heat. I am sure clad for AC down here in Florida. LOL Oh awaiting the hurricane here in No Fla
Thanks
Beachlife
Go to Costco and get yourself a set of Bridgestone Dueler A/T Revo 3.
Then order a set of Bilstein shocks.
then you will be good to go
2002 Chevy Roadtrek 190V
https://www.roadtrek190.com
Old 04-03-2024, 04:43 PM   #23
I will also vouch for the Michelin Agilis Crossclimate, it is a massive upgrade over the stock tires (which wore out for me at about 30k - my MACs still look like new 50k later).
Old 04-03-2024, 04:51 PM   #24
The blowouts and tread separation is on the stock van tires: Nexen Roadian LT225/75R16.
Do not use these tires! They will fail, I think Ram and others put them on as they are very quiet and smooth. But with any load added to the tire and freeway driving they will fail.
Dave-DJ is offline   Reply With Quote
Old 04-19-2024, 05:25 PM   #25
I ended up with Michelin Agilis LTX.
Old 05-16-2024, 05:06 PM   #26
Michelin Agilis Cross-climate provide a better ride with less road noise than Nexen OE tires. Just put 1800 + miles on them with no complaints.
PatMM is offline   Reply With Quote
Old 05-16-2024, 05:09 PM   #27
Default No argument from me...I agree 💯 percent
Michelin Agilles Tires are perfect. They are smooth handling tires and wear well.
Old 05-18-2024, 09:15 PM   #28
Default Tires and shocks
Originally Posted by Roadtrek Adventuous RS1 View Post
There's no argument about choosing Michelin Agilles tires, they are great. I've read on other forums that some people chose Cooper Tires as a lower cost alternative.
I have Michelin on my van with Koni FSD shocks.... it's very smooth. Doesn't really matter on the mileage because for safety it's highly recommended to change the tires every 5 years.
Also, for safety, consider a tire pressure monitoring system.
Looking back, do you feel the Koni's were worth the money? What did you change from "shock wise"?
Thanks, G
2012 Airstream Avenue Suite, based on 2010 Chevy 3500
StreaminGuy is offline   Reply With Quote
Old 05-19-2024, 12:04 AM   #29
At 39,000 miles I had the factory Mercedes Benz Sprinter shocks replaced. The problem with the original shocks is that they were designed for a cargo van. My conversion van has the constant weight of all the equipment and is always present.
Yes, it was definitely worth it. And, I had the factory anti-sway bar replaced at the same time with a much larger unit.
It doesn't handle like a sports sedan, but, it is a much better controlled ride.
