06-17-2021, 10:34 PM
New Headllamps for 2008 RT, + Replacement interior light
The headlamps on my 2008 RT 190 Popular (Chevy 3500) are badly scratched up making it difficult to see at night. I have checked local junk yards to no avail. I did a quick search on line but maybe I am not using the right search words as I do not see what I need.
Also one of the interior lights is broken. Any ideas on where to find that?
Any help would be appreciated.
Thanks,
Marie
06-18-2021, 12:38 AM
amazon $86 bucks
fit 2003~2020
Mine were perfect for my van
HOWEVER I bought same branded "eagle eyes" for my 2001 sierra and the headlights sent out were broken ( adjusters) or optically flawed.
I just kept returning them and amazon ate the shipping ( prime member)
it took a total of 5 to get 2 good ones for the pick up
you'll be happy to have better eyes up front
06-18-2021, 01:05 AM
I don't have a Roadtrek to suggest an interior light replacement. But I have a Chevy Express 3500 and I've replaced my headlights recently. They are incredibly cheap. Don't bother with junk yard replacements that are probably as weathered as your old ones.
I bought a pair of "Eagle Eyes" off Amazon. The seller is no longer listing them, but I found these: https://www.amazon.com/AmeriLite-200...rfy_rp_crs_2_t
They usually (check to be sure) come in pairs for $85 or less. Complete with bulbs. Just plug & play.
Very tight getting the old ones out. But, you only have to remove a couple of top bolts and then wiggle them up and out. Wires easily plug right in and out.
The difficulty to getting the new ones in, is the bottom tabs. I had some difficulty getting both tabs into their slots at the same time. I also had to pull on the grill and fender a bit to make the slightest fraction of extra gap for them to fit into place.
Prior to installing, I marked the vans low beam level on my garage door with tape. After the install, I used those marks to adjust the beam level.
Difficult, but not too difficult. Took me less than an hour and only a few mild curse words.
06-18-2021, 01:50 AM
I bought mine from
https://www.rockauto.com
TYC 20658100 and
TYC 20658200
2008 Chevy Roadtrek. Same style as in the pic.
Happy with the quality.
06-18-2021, 02:28 AM
Gotta love the Chevy Express when it comes to the price of replacement parts. I tell my wife it's one of the advantages of driving a "plumber's van".
06-18-2021, 04:01 AM
Ok, so Group B and rowiebowie either suggestion should work for me since I have a 2008 RT on a Chevy 3500 body, correct? How do I know it's an Express? I'm pretty handy bit I guess I should have someone install them. Probably not worth the aggravation to DIY.
Thanks,
Marie
06-18-2021, 05:34 AM
so easy to replace.
I'd say mine took 20 minutes including the making the coffee part
the Chev van is called an "express" ( GMC is a Savanna) and comes in various versions 1500, 2500, 3500
06-18-2021, 02:09 PM
Marie
The suggested headlights will fit your van. It was a very good idea on your part to include a picture, but yes, yours is a Chevy Express 3500. The headlights would be the same for a 1500, 2500, and 3500 since they are all the same friont end.
06-19-2021, 02:36 AM
There are 2 styles of headlights used on Express vans.
One is a composite type that is a plastic housing with 2 replaceable bulbs, low and high beam.
The other is a sealed glass beam that also houses the 2 filaments. If either fails, the unit is replaced.
I assume the type used on any particular van is related to the options included when assembled.
06-19-2021, 03:25 AM
Originally Posted by GroupB
There are 2 styles of headlights used on Express vans..
they posted a pic in their first post
it's the first "passenger" style common to class B's on express vans
mike
06-19-2021, 05:09 AM
Thanks Mike. What I have now is the plastic housing. So you're saying either one will work.
Marie
06-19-2021, 03:28 PM
Marie
As in my post #3 these will work: https://www.amazon.com/AmeriLite-200...rfy_rp_crs_2_t
Doesn't matter if you get them from Amazon, Rockauto, etc, you need to make sure they look like this, not the square version shown in bottom picture in post #9.
06-19-2021, 05:10 PM
The best quality headlights are the original ones. Unfortunately OEM replacements are extremely expensive. This article highlights a few of the aftermarket brands. They highlight the TYC and Depo brand as being pretty good quality, but not as good as OEM.
https://www.candlepowerforums.com/vb...e-Out-with-OEM
I decided to try the Cerakote Ceramic Headlight Restoration Kit based on the reviews and guarantee, and that I am using the OEM headlights. I am generally happy with the results, but it is does not bring the headlights back to original clearness. I did this a year ago and it is holding up pretty well.
https://www.amazon.com/CERAKOTE-Cera...omotive&sr=1-2
There are a lot of aftermarket headlamps available and while all of them look good on initial installation, time will tell if they hold up, especially the clear cover. I suspect some will cloud over in a few years.
06-19-2021, 06:04 PM
Originally Posted by rowiebowie
As in my post #3 these will work: Doesn't matter if you get them from Amazon, Rockauto, etc, you need to make sure they look like this, not the square version shown in bottom picture in post #9.
...as in my post #2 as well
don't over think it
amazon works best if you are a prime member
my experience with the van was excellent ( and the focus/aiming adjustment was 100% out of the box )
but for my pick up it took a total of 5 orders to get 2 which were optically correct
as someone else posted, park the van facing a wall or garage door and mark the high and low beams with tape
when you put in the new housings, use the adjusters to match your markings- if only 1 of the 2 ( high/low) lines up and the other is wacky, the lamp housing is no good, return/exchange for another
the idea of buying a lamp housing from GM for 8x the cost is silly
btw my headlights looked exactly like yours when I replaced them, the same horizontal lines which almost looked like stress cracks.
my cheepos have been in over a year, exposed to the AZ sun every day and are just fine
mike
06-19-2021, 06:06 PM
Our 07 Chevy is probably not a good example as it sits inside almost all the time, except when we are out camping. I would expect the lenses to hold up well. We did put the urethane(?) stick on covers on the lenses when we got the van, at that point it had seen a year of sun in the dealer lot. The covers are nice as getting the bugs off is easier and the rocks don't do much to them at all. Time will tell how they do over the very long term, but we are at 13 years on them now.
06-19-2021, 08:27 PM
Keeping a vehicle inside a garage, away from sun and weather, is indeed the best way to keep it looking new. Unfortunately my garage door is not 10ft high so mine sits outside 365. My headlights were much worse that the OP's picture when I changed them and my roof clear coat is quickly flaking off.
My wife's '97 Expedition, on the other hand, spent every day and night inside the garage. We owned it 22 years and it still looked new when we sold it.
06-19-2021, 10:52 PM
New Headlamps for Chevy 3500 PW
Hello, I agree with the recommendation of an earlier poster, you can't go wrong in purchasing the Eagle Eye brand. I just purchased on eBay a full set, headlamps and turn signal lenses including halogen bulbs for just over $100- you can't go wrong at this price buying new.
06-19-2021, 10:54 PM
06-19-2021, 11:04 PM
New Headlamps for 2005 Chevy 3500 PW
I wish I could have gone the restoration route, unfortunately, I had to go the replacement route as I had a broken housing on my right side turn signal lens and the headlights where no longer water tight; had condensation clouding up the lenses; no restoration product could help at this point.
06-19-2021, 11:50 PM
While I don't look forward changing my headlights every 4-5 years (just my estimate of projected life in the South Texas sun), it probably takes less time and lasts longer than doing a headlight restore using a kit. So you're probably better off.
