Old 02-13-2022, 10:48 PM   #1
Default New Beyond
Ordered in Oct, finally came off the assembly line last week. This will be B#5, 2 Sprinters & 2 Promasters, gotta try them all.
Toyman is offline   Reply With Quote
Old 02-14-2022, 02:52 PM   #2
Congrats! You simply must post a general comparision of chassis performance, ride, and handling once you have some miles on your new b.
Old 02-25-2022, 02:18 AM   #3
One thing, the Transit is worlds above the other 2 in power and transmission operation.
However the Promaster is now getting the ZF designed 9 spd trans as of '22 models
Old 03-01-2022, 06:38 PM   #4
Delivery on 3/10 ������������
Old 03-01-2022, 06:44 PM   #5
The Promaster seemed to me to be a little underpowered, esp when pulling out in traffic. In the same circumstances - pulling out crossing traffic - esp if you you are pulling out from a slightly uphill shoulder on gravel, you’d better make sure you have a good break in traffic.
Old 05-18-2022, 05:11 PM   #6
We got the Beyond, a little late, but got it. Really a impressive chassis, plenty of power, quiet and smooth riding. A little disappointed in the conversion, not totally unexpected, it’s a RV. We didn’t get the Li model, after my very expensive Travato experience that wasn’t happening again. Really like the Truma Combi, this is our 3rd such and have had no problems with any of them. What we consider to be the best of the best on the van is the AC unit. After begging and pleading, and a few discussions about my experience with RV AC units I got them to install one of their first Truma Aventa unit. This is THE AC for RV's, I don’t believe I will ever buy anything else, quiet and powerful enough for Houston weather. Not available yet as aftermarket item, but if it’s a order option, go for it!
Old 05-19-2022, 01:54 PM   #7
@Michael's Avatar
Thumbs up
I'm also a fan of the Combi. Ours had an issue with a solder joint on the circuit board, which Truma fixed under warranty. They hinted that the ground wire installed by Coachman was not properly secured & caused vibration and joint failure. Other than that, it's been perfect.
Good luck with the new van.
2019 Coachmen Crossfit
Old 05-21-2022, 05:05 PM   #8
Thanks & nice blog.
