Old 06-12-2022, 11:32 PM   #1
Default Need small window on 2005 pleasure-way excel
Hi, I am looking for the small front left side window for my 2995 Pleasure-way excel.
It's the little one in the top front of the roof. I found one through my local dealer but the price is out of site. $570 for the window and $300 for shipping.
Wow!
Does anyone know of a source for this window?? It probably would have to be the frame and window togather
Kingfish.h is offline   Reply With Quote
Old 06-13-2022, 02:17 AM   #2
this is probably flat glass- flat glass is the easiest to manufacture and work with and the cheapest
contact a local auto glass shop- they can use your other window for an exact mirror-image template
in your shoes I would buy a sheet of acrylic* at home depot and use a rotozip, dremel or jigsaw to cut to size
I'd guess $50 and an hour
mounting into the rubber seal is easy using grease and string ( see youtube)
if the rubber seal needs replaced check steele rubber products, they have all shape/profiles of window seal, weather stripping etc
* considering my PW windows are always covered, I might consider something tinted or opaque
https://www.homedepot.com/p/OPTIX-18...C-21/202038050
Old 06-17-2022, 01:33 AM   #3
Had to go to local glass shop today
presented with this "problem", they would cut glass to size and then have it tempered
they were telling me that Phoenix has 3 businesses which temper glass, and most other cities will have at least 1
they are kept in business by commercial and shop windows which require tempered glass ( by code)
mike
