Old 11-26-2018, 04:25 PM   #1
Default Need Replacement Cover for Outside Light
I have a 1999 RT 190 Popular. I recently discovered the plastic cover over the outside porch light is gone. It had gotten slightly melted when an auto parts place gave me the wrong light bulb, so I'm assuming the cover must have fallen out (although it had been that way for over a year). Other than contacting Roadtrek, is there a place to get replacement parts?
Old 11-26-2018, 05:24 PM   #2
jmai's Avatar
This one worked on my 2001 Roadtrek 190 Popular (Dodge chassis). I purchased it from Amazon.
Deco 008089-01-700 Porch Light Lens - Clear
Joe
jmai is offline   Reply With Quote
Old 11-29-2018, 06:45 PM   #3
Thank you SO MUCH for that information! I had no idea it'd be that easily available! One reviewer suggested installing an LED bulb to prevent burning the cover, so I'll be doing that too!
Thanks again!!
Old 12-02-2018, 08:34 PM   #4
I bought that same one a month ago and put an LED in
Perfect fit on a 2006 190 P.
Thevon is offline   Reply With Quote
Old 12-03-2018, 06:10 PM   #5
I haven't shopped for LED bulbs yet. Are these at RV or auto parts stores? Sorry for the stupid question.
Old 12-03-2018, 08:24 PM   #6
Bobow's Avatar
I have a 1998 RT 190. It has a light on the outside which I would assume is the porch light you are talking about. I have not found a way to turn the light on. Where is the switch.
Bobow is offline   Reply With Quote
Old 12-03-2018, 09:02 PM   #7
Bobow, the switch is on the monitor/control panel with the generator switch and the switch that turns on the battery power, etc. I tried to find a photo of the panel on line but couldn't find one at the moment. If I remember correctly (I'm not home right now), the switch doesn't look like it would be a light switch. My RT has the optional armoire, so my control panel is inside the armoire. I think the porch light switch is a rocker switch that will be closest to you on the panel. When I'm home tonight, I can take a look and get a photo.
outside light
