Old 06-28-2008, 05:41 PM   #1
Default Mystery switch
On the partition between the psssenger side seat and the toilet, I have three electrical switches.
The biggest one is the one installed at the factory. It monitors the tank levels, LP gas, aux battery charge, and turns on/off the water pump.
Below and to the left is the switch for the water heater.
However, I have a third switch which is to the right of the water heater switch. It is a simple on/off switch. Does anyone know what this switch is for.
I hope this description is good enough
Thanks
Steve
1999 Roadtrek 190 Versatile.
on a Dodge 3500 chassis
rivka is offline   Reply With Quote
Old 06-28-2008, 08:18 PM   #2
Could it be the aux battery disconnect switch?
When you turn it off do you lose the 12 volts in the van? Lights, bath fan etc.
Just a guess
FLSTFI is offline   Reply With Quote
Old 06-28-2008, 08:26 PM   #3
Should have added, go to the RT website and download the manual for yours
http://www.roadtrek.com/manuals.aspx
Old 06-29-2008, 12:37 AM   #4
Thanks for the reply. and the link!!. That helps alot.
Here's a pictire (hopefully), The switch I'm talking about is the lower right one.
Old 06-29-2008, 01:10 AM   #5
Default Mystery Switch
I would think it to be the outside light switch - mine is there. Ron
Ron J. Moore
'15 RT210P
Old 07-03-2008, 02:52 PM   #6
That's it. Thanks Ron
