Old 05-07-2018, 09:38 PM   #1
Default MSRP Negotiations
I am working to special order a Midwest Automotive Designs 2019 Passage through a local dealer. I have an MSRP from MAD and an offer from the dealer. The offer discounts the MSRP 5.8%. From previous experience buying four other rv’s, I know 15-20% seems reasonable. The salesman is telling me MAD does not overinflate their MSRP so there is little room to negotiate. Seems hard to believe they would deviate from the rest of the market practice. The dealer also is low balling my 2015 Airstream Flying Cloud 28T and 2017 GMC Sierra 2500HD 4x4 trade in package. I’ve researched what’s on this forum regarding MSRP discounts. Does anyone have any related recent buying experience? In particular, thoughts or dealings regarding Midwest Automotive? Many thanks.
billhirst is offline   Reply With Quote
Old 05-07-2018, 09:47 PM   #2
You may want to look at this site, as they have a bunch of Midwest stuff and have been selling them for quite some time.
https://www.lakeregionrvs.com/defaul...tive%20designs
If you click on the the pic of the van in the list, the page that comes up should show you list and offered price. I assume you could also do a bit better than the offered price. The first van looks to be offered at about 20% off.
Old 05-07-2018, 10:15 PM   #3
Great reference site. Sure looks like 20% reduction off MSRP for all units. I’m sure when I show this to the dealer, I’ll hear it’s because it’s the end of the model year! Seems like a similar discount for a new model year order that won’t sit on their lot would be possible. Thanks again.
Old 05-07-2018, 10:20 PM   #4
I looked at a lithium equipped Midwest and a Coachmen Galleria side by side a few months ago and they were similar in build quality which was darn good except for the cabinetry in which the Galleria was the winner. I would out-the-door price both of them. I don't know what discounts from MSRP are available for Midwest. MHSRV sells Gallerias for 25 - 29% discount. If your interest is in the lithium and/or 4WD options it might be worth waiting a while until supply meets demand.
Old 05-08-2018, 12:38 AM   #5
wincrasher's Avatar
If you're wanting a Sprinter, I'd hold off until the Era is introduced with the Volta lithium system. It's superior in every way to the Xantrax system that Coachmen is using.
Era has seen many improvements on the interior, and should be able to house the largest Volta battery without issue - 12kw-h!
2019 Winnebago Travato GL
Old 05-08-2018, 01:37 AM   #6
Would you also delay until the build is on the later generation Sprinter?
With respect to charging parameters, the Volta system is superior to the Xantrex system. Battery AH is a little higher with the Voltrex and at 48 Volts recharging is certainly faster, but both systems are hands above anything else available and I think that for practical purposes either setup would satisfy even power hungry boondockers. Undoubtedly Mercedes would prefer to see the Voltas on their Srinters because of the decrease in engine idle run time required for battery recharging. The Xantrex inverter/charger looks very well designed and the abllity to wirelessly monitor and program it is a real plus. What does Volta use for the inverter/charger and can it communicate wirelessly like the Xantrex?
Old 05-08-2018, 02:09 AM   #7
IMO, the 48 volt alternator and charging system, that won't heat cycle and charges much faster, plus the smaller wires and less heat in the equipment is a very big deal.
Volta is using Sensata inverters and chargers, IIRC, which are really Magnums. They are very good pieces, and I would rate them higher than the Xantrex, but others may not. Things like wireless mean very little to me, as hardwired is just fine, and the Magnum chargers with the right remote have built in battery monitor capability, so lots of experience.
Old 05-08-2018, 03:46 AM   #8
wincrasher's Avatar
Since the Magnum is a networked device, there may be the possibility to add a wireless dongle to the mix. Not sure, but not really a deal breaker for me.
I'd be more interested in a bluetooth dongle for the solar controller. I've been spoiled by my Victron Blue controller and the monitoring and data logging I've been able to do on my phone & laptop.
The battery capacity of the Volta over the Xantrax system is not minor. The Xantrax is using the 600 AH Lithionics battery - that's 480 ah-540ah depending on how you set your limits (80-90 SOC). The Volta battery ends up being over 800 ah of usable capacity. The battery is the 10kw-h model - but WGO is marketing it as 8700 ah useable. Also, a little birdy told me the box has room for another 3 kw module bringing your total over 12 kw.
Old 05-08-2018, 05:03 AM   #9
Lithionics said they will supply any ah capacity desired in 160ah increments in either single or split modules so for DIY builders, with regard to ah capacity, there is potentially parity with Pure/Volta. But space limitations makes it unlikely that Coachmen or MidWest would let the buyer opt for any capacity beyond 540-600 ah.
Old 05-08-2018, 03:50 PM   #10
wincrasher's Avatar
Yes, Lithionics can provide modules of various sizes and their BMS allows daisy chaining their batteries. That's often how they handle it in boats (they are big in marine applications) where there are odd, disjointed spaces for storing batteries.
But Coachmen's design scheme (to reduce costs I imagine) is to place the batteries inside the coach. This limits how big they will go with capacity, as you have competing needs for other equipment as well as storage space. The 600 AH lithium block is tightly wedged in where they put it.
The Volta scheme is to put the battery in an insulated and thermally controlled box underneath the van (where a generator would normally reside). They also seem to be having a one-size box, as the one supplied to WGO has room for an additional module in it.
One could argue which design scheme is better - they each have their plusses and minuses. What I think is harder to get past is going 48 volts. It solves a multitude of issues and certainly has some performance benefits.
Old 05-08-2018, 04:32 PM   #11
Default Did the deal
The dealer increased the MSRP discount to almost 15% and increased the trade in values for the Airstream and Sierra. So, we agreed on the deal. The build time is 16 weeks. Meanwhile, the discussion on lithium battery systems gave me pause, but I decided the Xantrex system will more than meet my needs. And, if you wait for the latest technology for anything, you end up with nothing. Anyhow, by next fall I should have some feedback on howgozit with the MAD Passage with the “freedom” package. Thanks for all the good comments.
Old 05-08-2018, 10:01 PM   #12
Volta claims that their battery design (chemistry?} is superior to mainstream lithiums. What's your take on that?
Old 05-11-2018, 11:02 PM   #13
We recently bough a Midwest Automotive Weekender - Just in March. I would think the negotiation process is about the same. Just be smart, savvy and stick to your guns. Find comps, ask around. We held out a got a better price, but our was an new but older model on the lot. You may have a harder time with a customer order. I do know that they recently dropped their MSRP about ~25K, but it was rather inflated to begin with. Now there is a difference between the dealer and the manufacturer. Which are you really referring to. We had pros and cons dealing with both. Where are you located?
Djette1 is offline   Reply With Quote
Old 05-12-2018, 02:22 AM   #14
I'm finding not sticking to the thread subject rather irritating because I answered this question in another off subject thread which I cannot recollect now. Anyway, an amp hour is an amp hour. The difference from mainstream lithiums, what ever that is, probably LiFePo4 batteries, is the Volta batteries are a different chemistry (NCC I think) and they claim they can go down to a -40 deg. F. without damage vs. -4 deg. F. for my batteries. That's significant. -40 deg. F. is the same as AGMs. However all lithium batteries are subjected to no charging colder that 32 deg. F. The Volta system charges at least 2X times my batteries. That is not because of the batteries but the 48v system.
The Lithiumwerks Valence batteries are LiFeMgPo4 and can go down to -40 deg. F. without damage as well. They have an internal BMS for each battery in a type 24 or 27 case. The type 27s have a 138ah capacity.
Old 05-13-2018, 05:00 AM   #15
In terms of freezing points, theoretically the Volta battery and an AGM have similar freezing temperatures. But practically, isn't it more in favor of the Volta considering that it's unlikely that the AGM will conveniently be in a full state of charge when it's subjected to a brutal cold spell and consequently may have a freezing point significantly less than -40F? By comparison, whatever the freezing point of lithiums, isn't that temperature largely independent of their state of charge?
Old 05-13-2018, 06:12 AM   #16
wincrasher's Avatar
LOL. That is amazing!
But I doubt my van will ever see 0F, let alone -40F. Cold is not my thing baby!
Old 05-13-2018, 07:11 AM   #17
Oh yeah???? Check this out, particularly the places where you might think you could never see such temps:
Coldest ever in each state:
50.*Hawaii, 12*on May 17, 1979 at Mauna Kea Observatory 111 on the Big Island
49.*Florida, -2*on Feb. 13, 1899 at Tallahassee
48.*Louisiana, -16*on Feb. 13, 1899 at Minden
46.*Georgia, -17*on Jan. 27, 1940 at CCC Fire Camp F-16 (near Beatum)
46.*Delaware, -17*on Jan. 17, 1893 at Millsboro
44.*Mississippi,-19*on Jan. 30 1966 at Corinth
44.*South Carolina, -19*on Jan. 21, 1985 at Caesars Head
43.*Texas, -23*at Seminole on Feb. 8, 1933
42.*Alabama, -27*on Jan. 30, 1966 at New Market
41.*Rhode Island, -28*on Jan. 11, 1942 at Wood River Junction
40.*Arkansas, -29*on Feb. 13, 1905 at Gravette
39.*Virginia, -30*on Jan. 21, 1985 at Mountain Lake Biological Station in Pembroke
38.*Oklahoma, -31*on Feb. 10, 2011 at Nowata
36.*Tennessee, -32*on Dec. 30, 1917 at Mountain City
36.*Connecticut, -32*on Jan. 22, 1961 at Coventry
34.*New Jersey, -34*on Jan. 5, 1904 at River Vale
34.*North Carolina, -34*on Jan. 21, 1985 at Mt. Mitchell
33.*Massachusetts, -35*on Jan. 12, 1981 at Chester
31.*Indiana, -36*on Jan. 19, 1994 at New Whiteland
31.*Illinois, -36*on Jan 5. 1999 at Congerville
29.*West Virginia, -37*on Dec. 30, 1917 at Lewisburg
29.*Kentucky, -37*on Jan. 19, 1994 at Shelbyville
28.*Ohio, -39*on Feb. 10, 1899 at Milligan
24.*Kansas, -40 on Feb. 13 1905 at Lebanon
24.*Missouri, -40*on Feb. 13, 1905 at Warsaw
24.*Maryland, -40*on Jan. 13, 1912 at Oakland
24.*Arizona, -40*on Jan. 7, 1971 at Hawley Lake
23.*Pennsylvania, -42*on Jan. 5, 1904 at Smethport
22.*California, -45*on Jan. 20, 1937 at Boca
20.*Nebraska, -47*on Dec. 22, 1989 at Oshkosh
20.*Iowa, -47*on Feb. 3, 1996 at Elkader
19.*Washington, -48*on Dec. 30, 1968 at Winthrop and at Mazama
13.*Utah, -50*on Jan. 5, 1913 at East Portal
13.*Vermont, -50*on Dec. 30, 1933 at Bloomfield
13.*Nevada, -50*on Jan. 8, 1937 at San Jacinto
13.*New Mexico, -50*on Feb. 1, 1951 at Gavilan
13.*Maine, -50*on Jan. 9, 2009 at Big Black River (near Saint Pamphile on the Canada border)
13.*New Hampshire, -50*on Jan. 22, 1985 at Mount Washington
12.*Michigan, -51*on Feb. 9, 1934 at Vanderbilt
11.*New York, -52*on Feb. 18, 1979 at Old Forge
10.*Oregon, -54*on Feb. 10, 1933 at Seneca
9.*Wisconsin, -55*on Feb. 4, 1996 at Couderay
8.*South Dakota, -58*on Feb. 17, 1936 at McIntosh
5.*North Dakota, -60*on Feb. 15, 1936 at Parshall
5.*Idaho, -60*on Jan. 18, 1943 at Island Park
5.*Minnesota, -60*on Feb. 2, 1996 at Tower 2S near Lake Vermilion
4.*Colorado, -61*on Feb. 1, 1985 at Maybell
3.*Wyoming, -66 on Feb. 9, 1933 at Riverside Ranger station in Yellowstone
2.*Montana, -70*on Jan. 20, 1954 at Rogers Pass
1.*Alaska, -80*on Jan. 23, 1971 at Prospect Creek
All data gathered by the*State Climate Extremes Committee. In case of a tie within a state, most recent data was used
Old 05-13-2018, 02:00 PM   #18
The Mauna Kea Observatory is at 4,200 meter
At that height, you will find ice and snow in Africa too.
ps. not saying you are wrong; just pointing out the State Climate Extremes Committee's data.
Old 05-13-2018, 02:37 PM   #19
I overnight camped in Gallup, NM at a Cracker Barrel when the temperature got down to 0 deg. F. My lowest temperature experienced at my home in Minnesota was -43 deg. F.
Old 05-13-2018, 02:57 PM   #20
Those are published numbers. The details can be debated but the point is AGMs are not necessarily superior. Any battery subjected to cold temperatures is not good. However, because lithiums can’t be charged when battery temperatures go below freezing they are more likely to have a built in heating protection and not subject to low temperatures. My batteries stay above 41 deg. F at all times. The core battery temperature to get down below freezing would have to have a sustained ambient temperature of around the lower 20s.
I am undecided on my next van batteries if I get on between the Volta system and Lithiumwerks Valence batteries (LiFeMgPo4) that also can go down to -40. Advanced RV will be offering the Valence batteries but I don’t think they have installed them in a customer’s van yet. Lots of testing and system design yet.
