Old 06-20-2018, 04:55 PM   #1
Default Monitor panel Not Lighting Up
My monitor control panel for water/black-gray tank/battery levels is not lighting up. I checked all fuses and flipped all circuit breakers. Is it possible all lights could be burned out? The water pump and generator lights do come on the same panel when turned on.
Alprater is offline   Reply With Quote
Old 06-20-2018, 10:07 PM   #2
Have you checked to see if your house battery might be drained down, or dead? Ron
Ron J. Moore
'15 RT210P
