Old 04-10-2020, 12:12 AM   #1
Default Mercedes/Winnebago Era window
I have a 2018 Mercedes Winnebago 170A. I overtightened the 'crank' on the window on the sliding door and now the window won't close tightly - and ideas?
Steve Lesniak is offline   Reply With Quote
Old 04-10-2020, 12:16 PM   #2
DUTCH in Atlanta's Avatar
Contact Winnebago, as it's probably a window upfitted by them.
Old 04-16-2020, 06:17 PM   #3
I also have 70A 2019, I use a Philips screw driver on the inside crank and open the window all the way and they closed it. In my case the plastic crank handle/knob stripped just a enough so it slip did not close it at the snug part...
mdstrum is offline   Reply With Quote
Old 12-28-2020, 03:33 AM   #4
3 of our cranks have failed. Common problem. My husband found the part that needs to be replaced (the operator) aka gear box, after much searching and phone calls from www.mobilehomepartsstore.com. 910-277-7202. Part number WCM#812. “Jalousie window center mount operator”. It was $9.99 plus S&H. It took him 30 mins to change it out. He has now ordered 7 more as he assumes all will fail.
Barbcnm is offline   Reply With Quote
Old 12-28-2020, 01:27 PM   #5
One thing I have found that helps is to keep the jalousie window gaskets lubricated with a bit of oil. I found they like to stick when closed and this put a lot of pressure on the opening mechanism.
Dave
Era 170A
magicbus is offline   Reply With Quote
Old 12-29-2020, 08:36 AM   #6
Are these the CRLawrence windows?
coss370 is offline   Reply With Quote
Old 09-29-2021, 07:15 PM   #7
Can you tell me how he was able to remove the "gear box" from the rod to replace it?
DDoyscher is offline   Reply With Quote
