Old 07-06-2017, 02:24 AM   #1
g1g
Default May have had a close one
I had the genny running for the AC and was out roaming around. when I got back I noticed it sputtered once in a while , I just filled up with a no name gas. Then I also noticed there was a smell of gas. I wasn't sure what was happening if it was running rich or what but I shut it down. I started moving out an when I circled around I noticed a puddle. Went to smell it and found out it was gas. Further checking showed it was dripping from under the genny. After that I had thoughts of it bursting in flames, I haven't had time to check it out yet if it is the carb or just the line. Either way it has to be dropped down to check it out.
Old 07-06-2017, 02:27 AM   #2
Wow... glad you caught it in time.
Old 07-06-2017, 03:04 AM   #3
Glad you were parked and seen the puddle, and alright...we have seen what happens with gas or propane when something goes wrong - it really goes wrong. Ron
Ron J. Moore
'15 RT210P
