Old 09-24-2023, 09:34 PM   #1
Default Macerator pump
Good afternoon all, my wife and I just purchased a 2005 Roadtrek 210 popular with only 27000 miles on it. We believe it was a score deal. Unfortunately, the party that we purchased it from had Alzheimer’s pretty bad, and was not able to go through the unit and answer all the questions. We are very accustomed to RVs how they work with the exception of macerator pump. I know that one lever is for Blackwater. One is for the gray water and there’s one more lever on it that I’m not sure what it does. If there’s anybody out there that could help answer this question. It would be greatly appreciated.
Wiser2 is offline   Reply With Quote
Old 09-25-2023, 04:18 AM   #2
the other lever is likely the extended crank for unsticking the macerator if it gets jammed. Shaft that runs to the macerator service port. My 2007 has a spring loaded lever, push in and turn to manually unstick a jammed macerator.
edit: get or read the roadtrek manuals, loads of info in there! I know they are available online if you didn't get hard copies
2007 TurdWrek 190 popular
Todd
tlillard23 is offline   Reply With Quote
Old 09-26-2023, 02:12 AM   #3
Thanks for the info. I was able to download a manual finely.
Old 10-01-2023, 06:12 PM   #4
engnrsrule's Avatar
My 2005 has the same. The unstucker is a knob on a rod you push and turned.
