Old 02-05-2020, 07:53 PM   #101
The shaft end is already there and sealed, so the handle shouldn't cause a problem. But like booster stated, you may not miss it as it should be needed in only the rarest of occasions. And then, you can always crawl under and give it a turn by screwdriver. So your choice.
Old 02-05-2020, 08:37 PM   #102
On the motor end of the macerators I have gotten, the end bell on the motor had a removable little watertight cover in the middle of it to put a screw driver through to turn the pump if jammed by popping out the little cover. Roadtrek removes that and puts a non sealed adapter through a bigger, I think drilled out, hole that is spring loaded to be able to push in from the opposite side of the van to turn it. It is a clear path into the motor if water gets there, which is likely.
Old 02-05-2020, 10:33 PM   #103
I loosened the plate where the rod mounts. I think I will put a little silicon around the plate and tighten it back down. I might throw the rod in the side compartment and pull it out if I happen to need it. Regarding the ground wire... do you reattach the ground to the case (the old wire is riveted on) or is there a better choice for the ground. Thanks again.
jbucking is offline   Reply With Quote
Old 02-05-2020, 10:38 PM   #104
You may want to check to see if the hole size will let the rod through, I seem to remember it being bigger from Roadtrek than on the replacement pump.
I moved the ground to the frame of the van by picking a spot, drilling a hole, cleaning it and using a sheet metal screw and star washer under a ring terminal.
Old 02-05-2020, 11:12 PM   #105
Okay, Thank you. One more question. What is the point of this "necked down" portion of the intake for the macerator ? It seems like it would just create turbulence with the inbound "stuff". Is there any reason I should not cut off the "necked down" portion of the macerator intake ? The rubber adaptor just attaches to the larger diameter portion of the intake.
Old 02-05-2020, 11:37 PM   #106
My understanding is that it can go on a smaller hose if needed, bigger rubber grommet, or thread into a tank or fitting. In our new configuration, short was important, so I cut ours off.
Old 10-07-2020, 04:03 AM   #107
In my case, it was a bad switch.
rtv170 is offline   Reply With Quote
