lp not getting to appliances, need help
Hi , I have a 97 roadtrek, was out doing some maintenence on my rv, when I tried to put the dometic fridge on, it will not light on propane, but works fine on 12v, and shore power, so I went to put on the furnace, gave heat for a few seconds, then stopped giving heat, then I thought I would lite the stove, they both lit for about 5 seconds, then died out, went out to check the lp level, shows 3/4 full, open and closed the valve, which felt much easier than normal to turn, went back inside, tried to lite the burners again, same as before, lasted for a few seconds, the went out., so I have lp, but its not reaching the appliances, my first thoughts are either the valve, or the regulator, is there any way I can test to see if either of these is malfunctioning? I have never had a lp problem before, did some research online, but no real success yet, if you have any ideas, I would really appreciate it, thank you,,,,,,,,,,,Josef,,,
