Old 12-03-2007, 10:35 PM   #1
Guest
Posts: n/a
Default Lisence plate for Ontario
What plate is required for a 2005 Roadtrek 190P?
Does it require a plate for a truck or for a car/van?
Thanks
Old 12-04-2007, 01:37 AM   #2
I don't know how they are registered in Ontario but here in BC they get the same plates as a car.
Old 12-04-2007, 02:36 AM   #3
renrut's Avatar
Vans in Ontario can have either plate on them. I think the one with the sticker on the front plate is used for trucks and commercial vehicles. I just moved to Ontario and put standard car plates on my van. I would thing a "B" would be the same. I thought about Veteran's plates for my vehicles but didn't want to do the paperwork.
I haven't licensed my RV yet. I need to fix it up a bit to pass the safety. At least it's 30 years old and doesn't need that emissions test done. There's a lot of camping around here so I want to get at it as soon as I can in the spring.
renrut is offline   Reply With Quote
Old 02-06-2008, 02:28 PM   #4
Hallibagger's Avatar
Unless your "B" is used for commercial uses it is plated the same as a car in Ontario.
I have seen "Bs" plated as commercial, I do not know the advantages to doing this!
It might well limit your access to some roadways in the US which are signed "No Commercial vehicles".
We had this problem when I was towing a 5th wheel with my truck.
Hallibagger is offline   Reply With Quote
Old 02-06-2008, 11:55 PM   #5
I just did my B in October of last year, same as the car plate.
Rick is offline   Reply With Quote
