Go Back   Class B Forums > Class B RV | Owners Forums > General Discussion Forum
Click Here to Login
Old 01-28-2023, 05:04 PM   #61
Originally Posted by THEBRAIN View Post
]SteveJ I can wire the batterys, ground & LED but how is this done " Another gets wired to the starter relay"?are you tapping into the wire harness under fuse block? seams kindof complicated.
yes the guage you link to was my 2nd choice then I found out about the iratating blinking. can you post image of where you have yours mounted?
edit I just read on yboob to turn the backlight off and on, by pressing the V and % buttons simultaneously and holding for a second or two
thanks
I tapped at the starter relay wire near the relay which is mounted to the starter.
My monitor is mounted to a cabinet wall in our Safari Trek, not much help, I'm afraid. Sounds like you found a work around. We just leave ours on for a night light as we are rarely plugged in, thus no night charging and no blinking light in the dark. It only blinks when driving or the solar is putting out when not plugged in.
