Old 09-26-2015, 11:39 PM   #1
Bobow's Avatar
Default Leaky dump valves? 98' Roadtrek
Next problem with my 98' Roadtrek is leaking from what I can only assume is a situation with the dump valves. How would I check this? What is the next step to repair? thanks Bob
Bobow is offline   Reply With Quote
Old 09-27-2015, 02:05 AM   #2
once it's clean- or cleanish...
with both tanks empty and valves closed...pour a couple of gallons of water in the black tank.
see if you get drips overnight...put a pan under the drain.
then empty that tank
and pour a couple of gallons of water in the grey tank
once you figure out which tank is leaking ( or both) you can service the gate valves
here is an overview of how typical systems work
mike
Old 09-29-2015, 12:17 AM   #3
Bobow's Avatar
Thanks Mike. Your comments and the video were a great help. Now I just have to get the job done. Bob
